On my previous 87 TC, I mounted a boost and an AFR gauge in the spot where the factory EQ is. I bought some sheet plastic for the mount, cut the holes out, and ran the wiring behind. With the plastic painted a semi flat black, it looked almost factory. My current 88TC has the factory EQ, so have to find a work around. No pics though as this was years ago
Here is my current setup. Small bracket fabbed up to hold the 5" tach in a Fox Mustang type of location.
B do you have those LED cluster faces made that has a separate switch built in to turn on and off? Are they black or white faced in the day? They look awesome at night.
11-19-2016, 06:01 AM (This post was last modified: 11-19-2016, 06:02 AM by 23027.)
Just finished putting together my dash after ripping it all apart to do the V8 tach resistor conversion. Here are some better photos of my gauge setup. Had to re-pin the tach lead back into the harness. Also put in all new backlight LED's and did a solder repair to the flexible printed circuit board. Found a hairline crack causing one of the lamps to not turn on. I also put on a new steering wheel! Here's the after shots.
[quote=23027]B do you have those LED cluster faces made that has a separate switch built in to turn on and off? Are they black or white faced in the day?
They are electroluminescent overlays tied into the factory wiring. White face. I also have a set of silver face overlays that glow blue like these in a box somewhere. [Image: He6qejX.jpg]
