12-11-2022, 09:50 PM
(This post was last modified: 12-11-2022, 09:51 PM by 88turbomajor.)
Hi All,
Sandblasting, sanding, and polishing was a real learning experience. The first one took forever as I tried different techniques. The second rim literally took 1/4 of the time. The orbital sander is your friend! These cars are sure a labor of love sometimes....
Two done!
As soon as all 4 are done, I'll clearcoat them.
1984 Mercury Cougar 5.0L LS Silver/Gray (New 5.0L with E7 heads and HO cam)
Previous: 1988 Turbo Coupe
Mikey97D
Jan 2018
CONNECTICUT
12-12-2022, 03:54 PM
(This post was last modified: 12-12-2022, 03:55 PM by Mikey97D.
Edit Reason: more
Looks great!!!!
Did you sandblast all of them them started to polish?
12-12-2022, 04:23 PM
(This post was last modified: 12-12-2022, 04:24 PM by 88turbomajor.)
(12-12-2022, 03:54 PM)Mikey97D Wrote: Looks great!!!!
Yes. I sandblasted them to get all of the paint off of the insert areas and all of the machined lines in the wheel. Then I used an orbital sander using: 320, 400, 800, 1000 (wet), 1500 (wet), 2000 wet, then I used 2000 dry which actually started to polish them up pretty well. Then I used the Meguiars wheel polish using a drill and their attachment.
Appreciate it!
They are going to look great on your car! I bet they would look good on a black turbo coupe as well.
(12-12-2022, 07:51 PM)spittinfire Wrote: They are going to look great on your car! I bet they would look good on a black turbo coupe as well.
Thank you! I know they will too! So Black and the Dark Blue one I had, would match up great! Your silver one too!
Mikey97D
Jan 2018
CONNECTICUT
(12-12-2022, 04:23 PM)88turbomajor Wrote: (12-12-2022, 03:54 PM)Mikey97D Wrote: Looks great!!!!
Appreciate it! Thank you for sharing the process! I put the '93 Cobra's on my car because the original wheels were in poor condition. I would like to refinish them some day for the original look although there are not as many tire options as the 17" wheels.
12-14-2022, 05:07 PM
(This post was last modified: 12-14-2022, 07:10 PM by 88turbomajor.)
(12-14-2022, 04:20 PM)Mikey97D Wrote: (12-12-2022, 04:23 PM)88turbomajor Wrote: (12-12-2022, 03:54 PM)Mikey97D Wrote: Looks great!!!!
Appreciate it! Thank you for sharing the process! I put the '93 Cobra's on my car because the original wheels were in poor condition. I would like to refinish them some day for the original look although there are not as many tire options as the 17" wheels. That's not the complete story.
Here you go!
1) Sandblasted the wheel using white glass media.
2) Cleaned up the wheels using air chuck and then wiped them down with a tac cloth. I did not re-sand the insets. I left them a little rough from the sandblasting so the the primer would stick better (paint too)
3) IMPORTANT: created a template for spray painting the insets: used primer first, then Ford Argent Silver. The template kept the overspray to a minimum. SEE PIC
4) THEN I used an orbital sander on all of the flat spots and rim edges using: 320, 400, 800, 1000 (wet), 1500 (wet), 2000 wet, then I used 2000 dry which actually started to polish them up pretty well. Then I used the Meguiars wheel polish using a drill and their attachment.
5) Because each rim is a bit different, some surface areas might not buff up to the same "shine", but I'm hoping the clear coat will even it out more. This is my first attempt at anything like this so I'm a newby at it. I wanted a two tone, "daily" driver wheel. If you want a show quality wheel, new is the best option.
This is what I'm going for. My car with the wheels photoshopped on.
