Please read and tell me If I am wrong
Ohio88TC Offline
The guy says a T5 from a TC will work with a 5.0 Here is the message
I must say your wrong,It will work with the 5.0 if you swap the input bearing
& bell.Some T-birds used the larger input shaft as the 5.0's.The gearing is
lower,but most 5.0 owners like that for a better launch & 3rd gear passing
power.
[email protected] wrote:Just to let you know a T-5 out of an 87 TC will not
work with the 5.0 It has a smaller input shaft and the gearing is not setup for
a v8. Also the T-5 is a world class
Import Killer Offline
My brother bought a 5.0 and it had a TC 5 speed in it and it worked fine, but the gearing was weird.
1987 Turbocoupe
Painted sonic blue pearl
Ground effects w/S351 wing
17x9 Chrome Cobra Rs
255/45/ZR17 Kumho 712s
KYB suspension
MOMO shift knob and boot
K&N cone air filter, Gillis boost valve, T-3 turbo, ported intake and E6, A237 roller cam, MSD coil, Kirban FPR
Full 3" exhuast w/Ultra Flo muffler
Brute force clutch
White faced indiglo gauges
2 12" Rockford Fosgate subs and amp
Chuck W Offline
You can go that route but you will need the correct input shaft bearing/bushing for the TC tranny (it's smaller). Yes the gearing is different and the torque capacity of the TC tranny isn't as high as that of the 5.0l ones..even the later 86-88 WC ones aren't rated that high.
83 Pseudo-Coupe, 87 Ranger (soon to be 2.3T), 84 XR7, 86 XR4 and 62 Mercury Monterey (old n slo)
