Doing a 2.3 conv. on my 88 TBird.
I got the motor and tranny put in and wired to the point that it should start and it turned over. I then installed the fuel lines and after I tried to start and all I got was alot of clicking from the starter relay solenoid. Traced wires and the only thing I could find was the starter wire had gotten pushed against the tranny lines and there was a bare spot that would of grounded itself out. I fixed that wire and it still does it. I tried a new starter and different solenoids and didnt make a difference. The battery is fully charged and everything as I can tell after going over and over it id wired right. Nate
84 TurboCoupe conv. to H.O. w/3.73 and AOD
88 TBird w/5.0 converting to 2.3 Turbo and auto.
03 Ford F150 Supercrew
07 Suzuki Boulevard C50T
1983 Turbocoupe
1983 Turbocoupe
