DennySweet
Centreville,Michigan
Confused: I have been tring to find out whether or not to use these new KB Hyperutic pistons with my new motor. Esslinger says don't because they come apart. A few of the local SVO people say no problem. I e-mailed the tech support center at Silvolite to see if they had any intentions of coming out with forged pistons for the 2.3. Tech center tells me they have 2.3 turbo's that have run Hyper type pistons for 3 yrs now w/ blasts upto 24#'s of boost and have had no problem at all!
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
Forged is much prefered over the hyperucrackedit. If they weren't Ford would not have put them in in the first place.
Yes I have heard of people that have not had a problem, yet, no I wouldn't put them in an engine I build. Just my .02 why do you want to use them?
and jack rails.
methos
May 2001
Cynthiana, KY
I suggest either JE or Weisco pistons
Jason Schaffer
88TC - 5speed, all options but leather and sunroof
Mods:
Esslinger Prepped head, AiResearch T-3, 3.73 gears, Schneider custom grind cam, chromed rims, dynomax on the duals, and last but not least... new interior
AIM - Shizniblit
Jason Schaffer
Mods: 3.73 Gears
Finally getting it back together.
1987tc
Bicknell Indiana USA
I understand not being made of money and needing to save a buck when you can. However, it makes no sense to me to put a part in like a piston that is not at LEAST as strong as Ford did. Why make a moter more fragile? I would always have in the back of my mind that if I ever get some detonation I will be eating piston salad for dinner.... I went ahead and ordered a set of forged pistons for my rebuild on my 87tc and it is pretty much stock. BUT I know that I will have the basis if I want to do something more interesting later like a big turbo or what ever. THink you will remember how much you saved if you blow the motor?
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,roller cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear.
Tubular rear control arms and Kenny Brown trac kit brackets. soon to come, Installation of Caster camber plates and a custom built roll cage.
Wes Arnett
Linton Indiana
DennySweet
Thanks Guys I just needed a little more convincing. Denny
88TC,87TC,88Mustang,86S-10,82Toyota,2-88S-10Blazers,56 Merc
