pil pressure
mhopper220 Offline
got oil pressure gaud in it reading cold idle 58,warm idle 27,high rs 40 to 42.good pete?Will numbers change with difrent oil levels
thanks.............mike
Michael Hopper
The numbers aren't high. They are a little low but nothing to get worried about. What weight oil are you running - 5W-30, 10-30?
Oil level can affect the numbers but it more a function of oil temperature. If your a quart low, the 4 remaining quarts get circulated more quickly so the oil stays warmer (and thinner so oil pressure is somewhat lower
mhopper220 Offline
Makes sense,you were joking about 5w30 rite?
Im runing 10w40 what do you run? i've heard the more broke in a motor is, the more you should use a heavier weight oil. The only thing I know about oil is, you poor it in the motor.
Michael Hopper
GlassRooster Offline
The guy that sold me my TC put Mobil 1 15w-50..Is that Bad? I put Mobil 1 10w-30
David
87 TC Faded Burgundy with faded red interior
K&N and cold air ducting- rest is bone stock
02 Mazda Protege 5 Replaced Dead Saturn
99 Cougar- Wife's car new body style now Discontinued.
I run M1 15W50 during the summer months (June to September here) and M1 5W30 during the cooler / cold months.
tps87turbo Offline
Mee too & my pressure is high on the factory gauge.
Tony Sceia
Red 88 TC loaded with every option, Walbro 255, 3" SS Downpipe with Magnaflow SS 2.5 Cat Back Mustang Dual system Installed by BJL, 3-core Radiator, Star Stage 2 Clutch, Rebuilt T-5 Tranny, 140 MPH Speedo
Now I need to finish converting to Raven/Gray Leather interior & just do some Body work & she'll be like new.
Tony Sceia -
HIS Red 88 TC
mhopper220 Offline
[B]I run M1 15W50 during the summer months (June to September here) and M1 5W30 during the cooler / cold months.
[What is the advantages of runing 15w50 and 5w30 as aposed to the comon 10w 30&40 i've never heard of runing those other grades.sory aboute the spelling lol/B]
Michael Hopper
I run 15-50 in summer. And i don't drive it in winter. 5W-30 would be good in cold climate winter season
I think it sucks but my new Escape has the recommendation to run only 5W-20, year round. In other words Ford wants you to sacrifice engine life for cafe standards.
[This message has been edited by Pete D (edited 05-12-2004).]
Pete, the wifes 2002 Taurus 3.0 Vulcan also "requires" 5w20. I have been running M1 5W30 spring / summer / fall in it and M1 0W30 during the winter, changing it every 5K miles. I am 99.9% sure that doing that wont void the warranty (which is almost over anyway... has 31K miles) since it meets all Ford specs, except the "hot" viscosity spec. Even though the Motorcraft 5W20 is supposedly synthetic, from the fairly extensive reading I have done, it is FAR inferior to Mobil 1 synthetic.
Does that Escape have that HORRIBLE 5 speed automatic with no dipstick that requires the Ford dealer only WDS scan tool to change the tranny fluid?
The 15W-50 will change the oil pressure as opposed to the 10w-30 right?
David
