Dave D
Dec 2007
Saint Louis
Ok here is what im thinking of. Im thinking on buying a different intercooler.With a dual outlet. I want to run my intercooler up front and then pull my intercooler line's just like as before, but with the extra outlet i want to try to pull my air filter off useing the extra outlet on the IC And running my air from there. But will it draw to much air from the IC and not flow right to thorttle body. LoL does this even make sense????
Stinger header, 3inch down pipe, 3inch exhaust, 255 walbro pump, Gutted and polished intake knife edge lower, FMIC 3inch port's. Water injection homemade. ported head, stock cam.MAF Conversion megasquirtv2,IhI turbo looking to switch
firstsvo
Mar 2004
miller place, ny usa
Where would it pull outside air from? Sounds like a closed up unit the way you describe it (or at least the way I understand it) like a cooling system.
White '88 auto mostly stock, Black '88 5 speed nowhere near stock
Dave, The intercooler only sees/gets air that has already been drawn in through the filter -VAM - turbo. It a closed system except at the air filter where air enters. The intercooler is sealed like firstsvo said.
Dave D
Dec 2007
Saint Louis
Ok but when you use a front mount IC its getting air before the filter. Could you use two outlets and draw cooler air to the VAM??? or im shooting outside the bun?
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
Sorry Dave...does not work that way.
After the turbo compresses the air, the intercooler cools the intake charge. The better the intercooler the more power the engine makes. The physics of air compression are beyhond me. But the air charge is heated up. A good IC, really helps out, if it is a front mount so much the better.
Travis
jmthunderbirdturbo
Feb 2005
Ostrander, Ohio
i think i see what your getting at, but no, that wont work. if you use the intercooler to cool the charge air before its compressed, you will have a massive boost leak. see this drawing (from another site).
http://i180.photobucket.com/albums/x7/jm...oturbo.gif
let me know if this is unviewable or not helpful.
-J0N
Chad88TC
Aug 2001
Berlin Heights, Ohio
So the intercooler you are thinking of getting actually has 3 ports on it (if I understand correctly)? The intercooler has to be a sealed unit, if you were to run 10 lbs. of boost (if you could keep it running) it would go right out the filter.
'88 Black, K&N on VAM, Holset HY35, ported E6, 2.5" single cat-back w/dynomax muffler, gillis, RR cam, TA cam gear, Bosch BPV, Stock IC, Walbro 255HP, Kirban AFPR
Dave D
Dec 2007
Saint Louis
lol so im way of course here. but i was not going to run a air filter just i tube to turbo i tube to intake and 1 tube to vam. like takeing the second outlet and running the compressed air back to the turbo. But it my sound crazy the more i think about it the more problems i see happening..but logic of it sounds good.
TCKNIGHT76
Mar 2008
columbus, oHIo
What if you run 2 ics? 1 for the air in to the turbo and then 1 from the turbo to the motor? Will this work?
88 turbo coupe
Bov
Eatin bc
K&N filter cone style
Pony wheels
60mm tb have it ready to go on
98 explorer
5.0
Awd
KEEP IT OUT THE RED!!!!!!!
Quote:What if you run 2 ics? 1 for the air in to the turbo and then 1 from the turbo to the motor? Will this work?
The air in the turbo very quickly becomes the air from the turbo to the motor. One intercooler serves the purpose.
There isn't much sense in trying to cool air coming into the system, especially if that air comes from in front of the radiator (cooler). Lets say that we did try to "inter cool" that air and lets just say it's 75*F. What are you going to cool the inter cooler with? The air to cool the inter cooler is also 75*F. Unless you are going to use a water to air inter cooler and feed ice water into the IC, you will not achieve any cooling.
It is the compressing of the air in the turbo that heats it up and makes an inter cooler useful. This is why the intercooler is placed between the compressor outlet and the intake manifold. There are many variables but for example, a properly sized IC can receive air that is well over 300*F from the turbo and cool it well below 200*.
