pete-can't up load pic's
Ricky03 Offline
Pete for some reason I can't up load pictures. Can you help me out?
Ricky
bhpinto79 Offline
look here
http://natomessageboard.com/ultimatebb.p...9;t=000160
White - 88 5 spd w/Gillis & K&N
File name has to be all one word, NO spaces
Turbocoupe1.jpg = OK
Turbocoupe 1.jpg = no good
Files must be .jpg or .gif or.txt format
Files must be just under 500 KB each
You are limited to 40 files up loaded. If you try to exceed that, you will have to delete some older files first.
Are you getting any kind of pop up message when you try to upload?
