Perfect Tuning gauge
BradM Offline
FYI for those interested in a multifunction gauge. I installed the Perfect Tuning gauge using the gauge pod for 1994-2002 Mustang (GlowShift GS-107). Very easy install but the pod needs to be cut to accommodate the larger diameter of the gauge and the included gauge hold-down required a little modification to fit within the pod. The gauge is well built (aluminum) and has lots of options, including flashing when limits are reached (RPM, boost, temp, etc.).
Attached Files Image(s)
1965 Mercury Comet Caliente; 1968 Mercury Monterey; 1969 F100 Ranger; 1987 Thunderbird Turbo Coupe
Looks nice in there, is that the one from Stinger?
1988 Turbo Coupe, Black/Black, 5 Speed, Moonroof,  T3/T4 50 trim, ported E6, 255LPH, Kirban, 3" DP dual 2.5" w Hooker Maxflows, MGW shifter, K&N, Gillis valve, RR cam, Koni's
BradM Offline
(04-26-2021, 10:49 PM)Kuch Wrote: Looks nice in there, is that the one from Stinger?
Yes, Stinger. Works great with PiMP and has additional inputs to work as a stand alone gauge.
