PCV replacement
BabyBlueBird Offline
I have been going through and replacing gaskets on my TC and found that the original PCV and hoses are starting to go. I’ve read stingers forum on there Catch can set up to replace the PCV. Not sure if it’s worth it on a pretty much stock car. Does anyone know if motor craft part # EV-98-B is the pcv I need?
88Slowbird Offline
I read to use EV-127-A so that's what I run in mine
Black 1988 TC: RR Cam (with Esslinger cam gear), Stinger FMIC, Stinger 3" Exhaust, .60/.63 SVO Turbo, Pimp V1.4, Spartan2 Wideband, Bypass Valve, Hurst Short Throw
Mach 1 Red 1988 TC: Steeda Tri-Ax shifter, manual boost controller
EV127A is the correct part.
My Tbird 5.0 uses the EV98B.
