Thndrchckn420
Mar 2003
Winchester, VA
Anyone have the part number for the seal on the factory sunroof? Is it a Ford part or aftermarket? Supposed to rain Wednesday and I have an 1/8" gap around the seal on the new TC. Thanks
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
Do a search on "sun roof seal" and you will find a lot of info
Thndrchckn420
Mar 2003
Winchester, VA
Pete, I tried that. I couldnt find the Ford part number anywhere. Do you think the sunroof doctor's seal is better or as good?
I never did a sun roof seal.
83-86 weatherstrip = E3SZ-6351346-A
87-88 " = E6SZ-63502C12-A
I would suspect these are obsolete from ford
Try Green - see the Vender's page
Joe F
Jul 2002
Hawkins, Texas - USA
Sunroof Doctor's stuff works great, looks like factory. I redid mine a couple of years ago and it make a vast difference.
Joe F.
JR's Place - My 87 TC
Thndrchckn420
Mar 2003
Winchester, VA
Cool, thanks a lot guys.
2birdsinthefalls887
Feb 2002
Beacon Falls,Ct.
Good topic, I need one on my latest daily driver, it is quieter with the moonroof open in the vent position than closed. There was some earlier posts,(I used the search function) that stated the Sunroof Doctors weatherstrip fit so tight that you had to push up the sunroof to help it. Has anyone had this problem, and anyone with this problem, do you have an updated report?
Thanks Bill
88 Turbo Coupe,loaded 104,000,
88 Turbo Coupe,Fully loaded,
2birdsinthefalls887
Feb 2002
Beacon Falls,Ct.
Oh, and by the way, the sunroof on the other daily driver doesn't work at all.( but it is real quiet,LOL)I found the post about the cold solder, WHAT THE HELL IS COLD SOLDER?
Thanks again Bill W.
firstsvo
Mar 2004
miller place, ny usa
Did the sunroof doctor seal. Car is guiet as can be, but the seal lets in NO water, as in the drain tubes don't see any water. I do have to push up on the glass to get it open in the vent position. No big deal. Works well.
Bill, I think what was meant is "cold solder JOINT". The soldering process didnt "take", and although the solder joint looks OK, it isnt making electrical contact. Many times just hitting the joint with a soldering gun and remelting it will cure the problem. "Cold" solder joints were the main problem with the GM PCMs in the 80s / early 90s that caused so many PCM replacements.
