Parking Brake Removal from Brake Caliper
Chemist Offline
I searched and found several related posts but none that answer my "simple" specific problem:
How do you remove the parking brake cable from the rear brake caliper. I have removed the C washer and have the end of the cable free - and based on the new caliper I purchased, the parking brake cable just fits in a hole in the metal of the caliper - BUT I can not get the cable holer out of the caliper hole.
Any techniques, tools, suggestions?
Thanks!
DennisWRaichart
Ryan H Offline
It is rusted in place. After you remove the c-clip, spray some PB Blaster or equivalent on it and let it sit for a few minutes. Then come back, take an old flathead screwdriver and press the tip against it and hit it with a hammer to drive it out. Make sure you remove the cable itself from the caliper first.
If you mean the cable end is in the slot in the caliper and you cant get it out, unbolt the caliper and remove the brake hose first. that way you can move / rotate the caliper to get it out.
Robert Camp Offline
Yep, the outer cable bushing is rust welded to the guide hole. Try using a drift first.
Then again I think I remember reading somewhere that screwdrivers had a fairly unique purpose. I've always thought they were multipupose tools; chisel, drift, pry bar, center punch. Never could figure why the manaufacturers couldn't make a tougher handle though, mine keep breaking, as well as the tips. <grin>
Robert Camp
DonH Offline
I hope you bought a new cable as well as a caliper but it is easier to remove if you disconnect the other end and remove the cable and caliper from the car and work on it with the old caliper in a vise. If you work on it with the caliper in the car the probability of not doing any damage to it is very low as you are going to have to hit it pretty hard numerous times to get it out. It is much easier just to cut the cable and sheath and hammer away at the center of it. When you put the replacement cable in clean the rust out of the hole and coat the cable mount with silicone grease (NAPA Sil-Glyde 765-1351 or similar) before installing. Use the same grease on the caliper bolts, the pad contact areas on the caliper mount, the piston where it contacts the pad, the cable where it moves thru the sheath, the lever seal where the shaft enters the caliper and the cable adjuster. And Robert, you should only use that really big screw driver that came with the set to pound on, you know, the one that's foot long and you never found a screw big enough for it.
1987 TC stock except ATR 2.5"
