Thndrchckn420
Mar 2003
Winchester, VA
What do I need to order from PA Performance to upgrade to 130amp? Is it just the alt and the wire kit? Do I still have to find a plug from the J/Y or do they (PA) supply that too?
I already have the 10 gauge wire and terminals as per thr tech articles.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
Keith Nubel
Liberty Township, OH
They have the complete kit, just tell them what it's for. I'm buying the wiring kit for the 85. They said it just plugs in. It should be listed on their web site.
1985 TC
Thndrchckn420
Mar 2003
Winchester, VA
This is the email they sent me when I asked them about a kit for my 88TC...
"The 88 Turbo coupe was made with a 75 amp MITSUBISHI alternator - not a Ford. We don't publish an "upgrade" because we have not done it ourselves, but I know customers have. You would need the alternator, our part # 1619 and a wire kit, our part # 462802A because although your alternator plug has the 3 pin connector, the Mitsubishi circuit does not use the center pin but the Ford unit requires it. If it were my car I would start there. You may be able to find others on the web forums who have done it. Don't forget to make or buy a heavy power cable too, that stock #8 gauge will not take that much power."
So I wanted a second opinion from someone who has done it to make sure the PNs they gave me will work. I get nervous thinking about splicing wires and stuff, so I want to make sure Im at least starting with the right parts.
Thndrchckn420
Mar 2003
Winchester, VA
Bump. Any help at all would be appreciated.
Just buy the alt and a stator plug from PA, get several feet of 10 ga wire, and follow the instructions in the tech article here.
Thndrchckn420
Mar 2003
Winchester, VA
Ok. Thanks a lot Jeff. It will be done. Merry Christmas!!
grey88smokin
Jun 2004
East Patchogue, NY 11772
I have done this following Jeffs write up. It is AWESOME, read it a few times if your confused on the wires. I read it like a dozen times
84 SVO 1C
08 MKZ
