I need to get new front and rear bushings.
It says in the P-S-T magazine state whether the front lowers are oval or round, i think there oval but not sure.
In the front, i put new sway bar bushings in, there is a slight loose felling in the front, i checked out the a arm bushings, they look worn. Are these the only four that will fix the loosness? everything else looks good.
