Overhead Console Removal
88chickentc Offline
Hi, folks.  I'm getting ready to do quite a bit of welding in the interior of the Bird.  I want to remove the headliner before I do.  However, I'd like a consult before I try to remove the map lights/overhead console.  The shop manual says to put a small screwdriver in the slot at the rear of the map light and pull down the edge.  Problem is that the only slot I see is at the front of the light.  If you look at the photo, you can see a small recess at the front of the light bezel that I assume is for prying.  I don't want to break the thing.  If anyone has pointers, I'd appreciate it.
Attached Files Image(s)
1931 Deluxe Coupe
1949 Club Coupe
1951 F-1
1971 Torino GT Convertible
1988 Thunderbird Turbocoupe
vegas_ss Offline
I don't recall which side but they do come out pretty easily. It should be the side that doesn't push in to turn the lights on/off.
88chickentc likes this post
88chickentc Offline
(07-09-2022, 10:26 AM)vegas_ss Wrote: I don't recall which side but they do come out pretty easily.  It should be the side that doesn't push in to turn the lights on/off.
Thanks.  That worked like a champ.
1931 Deluxe Coupe
1949 Club Coupe
1951 F-1
