Just got back from playing with my new manual boost control valve ($15 ebay).
I have to say it felt good to finally be able to feel the turbo. Everything in my signature is new to me. I use to have a stock IHI automatic car before this one.
First pull with the screw 3/4 way out didn't change boost very much at all. I was topping out at 10lbs.
Second pull with screw all the way out, same result. Therefore, I stretched the spring to make it tighter.
Third pull: Go Baby Go! Boost gauge blew past the red mark on the stock gauge. Then BANG! I'm thinking, oh sh!t. I messed up this time. I let it coast and idle. Stopped at the store to check everything. I noticed antifreeze blew out of the radiator cap and got all over the header panel. She seems to be running good so I readjusted the valve.
Forth pull: The spring is still stretched too strong. Now I can't get it to drop below 15lbs.
Final pull: I drove it home without the valve and typed this up.
I guess I need bigger injectors huh ?
T.C:87 5 speed
