Trying to get my little project car off the ground, car was not running when I bought it. Replaced the turbo due to damage on the inlet vanes. (po said it was leaking oil, and looked like it ate some dirt) Then I had no spark, found a bad pip and tif, still no spark and found bad coil. I also replaced plugs, wires, cap and rotor... Then my starter took a crap. I have spark but no fuel. found tank rusted and pump dead. Replaced pump and tank with new filters. pcm still not grounding out the fuel pump relay but when I ground the pin at the eec test connector I now have fuel pressure. Then the ignition switch fell apart, and the connector melted. replaced the switch and hardshell connector, replaced the 2 yellow power feeds, and the gray with yellow tracer. From what I can tell that circuit is sending power to heated o2 sensor and abs hydro pump relay????(circuit 687).
Now I got the engine to start and run (but runs like crap)
run a pcm self test and get code 23 for tps out of test range. I still need to test and replace it if its bad.
due to the heat damage from the ignition switch should there be anything I should keep an eye out on, or look over and or replace? I did have the nest of fuse links out when I overhauled the dis and replaced the coil. I didnt see anything that looked burned or overheated.....
The good the windows roll up and down :thumbup:
vroooommmm
87 dark red coupe, 5 speed, gray leather - stock for now...
09 Tacoma double cab
89 GL1500 Goldwing
89 GL1500 Goldwing
