so i recently had to rebuild the bird because an exhaust seat fell out and, well, blew the motor up.
anyway, i used my other block, stock crank and rods with cp pistons. the head is stock with a bo port 1.1 cam and some mild gasket match porting on the intakes. the car is running a stinger 3 to 2.5 dual exhaust, no cat, and a cone filter with a manual boost valve.
the car is set at about 18psi and i have tried the timing at 10, 11, and 12 but i still get detonation at 3500-4k in 3rd 4th gear. i disconnected the knock sensor to see why it was "being held back" at the listed rpm. indeed the motor was pinging so the ks was doing its job.
i've run fuel pressure tests and found it makes 30psi with vac hooked up 40 without and at full boost its right about 56-58.
should i assume the fuel system is fine?
i just installed a wb sensor and its idle is around 14.5-15.2 it seems to move around a bit.
at wot it is in the low 12's to high 11's.
obviously detonation is a timing / lean problem but i just can't see pulling more time than what it was from the factory. i am running premium fuel and it has detonated on the last 2 tanks from different stations.
how about the vam? can it cause problems of detonation in any way that you have heard of?
i did a few hours of searching and found a copuple threads where people have had issues in the 3500-4000 range but with no solutions.
should i just buy a 255 pump and kirban and bump the fp. maybe i need to have my injectors flow tested? i really don't want to dump piles more money into the car, heck i talked my wife into letting me buy it because its a "gas thrifty" 4 cylinder and it has been doing nothing but costing me buku bucks. i already need to change out a steering poump that i just installed 4 days ago (it sounds like a jet aircraft).
any help would be appreciated
thanks joe
thanks joe
88 tc
t3/4 50 trim stage 2 .48, bo 1.5 cam, lightly ported e6,stinger 3 inch ex., mild intake porting, basic cone filter, kirban, new motor (factory rods, .020 cp pistons, stock head specs).coolingmist injection, esslinger cam pulley.
