Ok guys need help fast. ECT wiring question!
sctur601 Offline
Ok I am replacing some of the wiring on my car because of some hack work and just old brittle wires. I am working on the ECT wiring now. I was pulling the tape off the sensor wires and noticed there is a resistor installed on one of the wires. Is this normal or is it some kind of way to bypass a bad ECT or something? The wires need to be replaced so I need to know if I am supposed to have this or not. Thanks
Shawn
Its an 83 tc with a LA3 swapped in if that matters at all?
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
And it still feels slow!
Thanks
Shawn
Please click the link if you want to sign my aftermarket head list
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
I also do port work, if you need something ported email me at [email protected]
sctur601 Offline
Ok guys with the key on the diode or resistor or whatever it is drops the voltage from 4.56v to 4.49v is this what its supposed to do? It realy doesnt look factory the saldering is a really crappy job.
Please help me!
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
Definately not factory. Putting a resistor in te ECT circuit will cause the EEEC to read a lower temp than the ECT indicates. Maybe this was a half assed try from some prior owner to fix a problem. If the EEC reads a lower temp than actually present, it will richen the mixture, and delay the switch to closed loop.
I have a 10K resistor in series with the ACT on my 5.0 so the computer reads the air temp as lower than it really is to keep the EEC from pulling timing in real hot weather.
TurboCoupe50 Offline
Sounds like TurboCoupe50 been working on it. Probably someone added a resistor to trick the computer. But if it is only making .07 volt difference it really isn't doing much. Does it have anything printed on it, or does it have color bands?
Two 1988 Turbo Coupes ..... yea one of em has a 5.0 And runs 13.3s
1988 Turbo Coupe331 AOD
1972 Comet GT
sctur601 Offline
What I was thinking maybe they added it to help stop the detonation problem the car used to have. another thing that was weird was the diode also had an extra wire hooked to it, it was a cheapy speaker wire one side was hooked befor the diode and one was hooked afterward! It ran into the interior of the car but was cut off. Maybe they had a toggle switch or something to bypass the diode? There has been some very weird things done to this car.
Thanks
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
My vehicle
1983 Turbo Coupe-
13.83 at 103mph!
Thanks
Shawn
