OK, guys, here is a strange one
The 88TC has been running great for several months and several thousand miles. Today, my daughter and I took a trip to visit some friends about 100 miles away. On the way home, traffic was light, and I was crusing at 75-80 mph all the way home. My 12 year old daughter likes to watch the A/F gauge bounce around in closed loop and she asked me why it stopped bouncing when we went over 80 mph (2900 indicated RPM). I tried to explain how the EEC went open loop at higher RPMs, etc... (I will turn her into a gear head if it kills me...hehe). Well getting into town, we slow to 60 to 65, and she notices the A/F gauge was not bouncing, but sitting right in the middle. A little time after she mentioned it, the CEL came on. No effect on how the car ran, though... A quick WOT burst up to 80 mph made the A/F go full rich, as always. After about 2 minutes, the CEL went off, and the A/F gauge started bouncing again, indicating closed loop operation restored. As soon as we got home, I ran the codes. KOEO: 28 (VAT code expected because it is 20 deg out today), continuous code 42: rich when closed loop expected. This obviously is what triggered the 2 minute long CEL. KOER: 25 (KS, expected) and 28 (VAT, also expected). Drove it around a little after the code test, and all seemed normal. I am leaning toward a EEC glitch as the cause of the CEL. I will check the TPS and VAF voltages to be sure they increase smoothly one of these days, just in case there is a problem there. BTW, fuel pressure is at 43 psi with vac hose off, and the regulator is good (fairly new Kirban AFPR), and 02 sensor is only about 8K miles old. Anyone have any other ideas???
Connector at O2 loose?? EEC brainfart?? [Image: biggrin.gif]
Ya, I am going to check the 02 connector, but I am leaning toward the EEC brainfart theory myself. Maybe the EEC felt it had to make corrections to the long term fuel trim for some stupid reason.
Dan E Offline
Geez, I was afraid to even suggest an answer...I mean when you are stumped Jeff, I feel like my God...who else would know the answer ? (I mean that with honest respect...).
My first thought was also the O2 sensor but...
Sometimes I feel that the EEC "learns" and adapts to periods of constant speeds and if you were in an extended period of time at one speed and A/F mixture...maybe it got "stuck" at that point. Just a hairbrain idea...
Maybe clearing the codes and/or disconnecting the battery for a while to re-set the EEC may have an effect ???
Dan Eaves
segfaultxr7 Offline
Jeff, I have the exact same thing happen sometimes if I run the car hard for a while and then coast. There's a stretch of interstate that is uphill for about 5 miles, then one exit is downhill for about one mile. Sometimes if I get off that exit, the check engine light will come on as I'm coasting downhill, then it'll shut off a few mins later. It's always a 42. I have a new O2 sensor and FPR, BTW.
Come to think of it, this almost always happens not long after I have disconnected the battery. Have you unhooked yours recently? I think you might be right about the EEC thinking it needs to make corrections. In my case at least, the EEC would still be making air/fuel ratio adjustments and running it in open loop so much might confuse it.
88 TC 5-speed
Good thought about the battery. I havent disconnected it recently, but it is about 5 years old, and the car does crank a bit slow in cold weather, especially after it has sat for several days without running. Maybe the batt voltage drops low enough when cranking the cold motor that the EEC keep alive memory resets, and then the EEC has to learn new fuel trim correction factors?
Walsted Offline
Quote:Maybe the batt voltage drops low enough when cranking the cold motor that the EEC keep alive memory resets, and then the EEC has to learn new fuel trim correction factors
Judging solely from the tripminder display, my EEC dumped everything when I had to jump-start my wife's car one morning. MPG went down to 19 for a tank and gradually improved back to normal with no changes to the car's set-up, so I assumed it was an EEC loss of memory due to the jump-start. If your battery is a bit old and tired, I could see it doing the same.
Mike Walsted - Nato member
1986 5-speed TurboCoupe .
TurboCoupe50 Offline
Jeff, for some reason Ford dropped the CEL in the 49 states TC's for '88. The CA and CDN cars still had it, now maybe we know why. There has been no CEL's on the eight '88s I've oned but the two '87s did have it.
Two 1988 Turbo Coupes ..... yea one of em has a 5.0 And runs 13.3s
1988 Turbo Coupe331 AOD
1972 Comet GT
Dan E Offline
Tom:
Are you saying that the CEL's on 88's just weren't hooked up or they were missing entirely ?
My 88TC has a CEL that comes on then goes off during KOEO or KOER.
Dan Eaves
Dan Eaves
Well, it has been 2 days since the CEL episode, and the car has been running perfectly ever since. The A/F gauge has been behaving normally, bouncing rich / lean several times a second as usual. Ran the codes again tonight (from the drivers seat, of course... didnt even pop the hood) after I pulled in the driveway after work, and everything is normal, except for the 28 and 25 which I expected. My conclusion: As Pete put it, EEC BRAIN FART. [Image: smile.gif] [Image: smile.gif]
Tom... very interesting about the lack of a CEL in some 88s. I think I'll start a topic on this surveying memebers and see how many have a functioning CEL.
