Oil & watercooled turbo
turbot4 Offline
I just received my new turbocharger from Turbo Engineering for my 1984 Turbo Coupe. The one I received has the ability to be watercooled whereas the factory was not. I just want to make sure that it is OK to have the turbo water and oil cooled?
P.S. It is a Stage II T3/T4 with a .48R/A rated up to 400 H.P.
1984 Turbo Coupe
Rebuilt Engine
New T3/T4 Hybrid Turbo
Large Spearco Intercooler with Bypass valve.
Adjustable cam gear.
Kirban adjustable fuel pressure regulator
K&N fender mounted filter.
8.8 readend with Ford Motor Sport 4.10's
Replaced entire brake system
Replaced entire fuel system
Replaced entire suspension
87' or 88' TC hood
Completely redone leather interior.
Turbo boost adjuster from Tiny Avenger
3" Exhaust - DP, Cat and Ultra Flo Dyno Max.
and just about every thing else...
Do not install that turbo----send it to me.
Seriously it is fine and to your advantage to have it water cooled. It should last longer.
Noname
Guest
If you don't mind me asking, how much did it cost? What's a # I could reach them at? Thanks, Tyler
turbot4 Offline
I will have to find out how much the turbo was, too hard to explain why I don't know. The turbo was bought at Turbo Engineering: 800-950-TURBo. Hope this helps.
1984 Turbo Coupe
Rebuilt Engine
87' or 88' TC hood
