Nsw
Apr 2004
Vancouver, British Columbia. Canada
Nsw
last fall i replaced my turbo and suppy line, problem is where the oil suppy line goes into the 90* fitting. when i tighten it down it faces the commpressor housing and i cant fit the line one. so ive just ben getting it as tight as i can and loading up hightemp gasket glue. it holds for a month or so then it stars leakin again.needless to say im getting tired of doing this. i treid searching but couldent find what i as looking for. could i used somthing like teflon tape or is there took much heat on the turbo?
thanks for any replys
tps87turbo
Feb 2003
Hammonton, NJ USA
I would use that liquid Teflon Tape or the pipe dope they use for boilers to help seal the threads. I think they should hold up to the heat.
Ryan H
Oct 2004
Panama City, FL
I used the liquid teflon, had the same problem. Just make sure you don't get any inside of the center housing or the supply line. I put mine on about half way down the threads to help prevent that from happening.
Nsw
Apr 2004
Nsw
thanks guys
Thndrchckn420
Mar 2003
Winchester, VA
Have you tried a new fitting? Over time, being tightened/loosened can 'wear' pipe thread because of the tapered threads and it will turn in more.
88 5-spd. Precision SC-50 ball bearing turbo, gillis, full 3" exhaust w/ 3- 1/2 crome tip, ported E-6, ported big exhaust valve head, ranger roller cam, Essy cam gear, K&N cone in front of the radiator, gutted upper, knife edged lower, Walbro 255HP pump, Kirban AFPR, Forge BPV, PA Performance 130 AMP Alt...
You should be able to get a new fitting at any good plumbing department. I've replaced mine before.
Or try McMaster:
http://www.mcmaster.com/nav/enter.asp?se...catnum=112
