In the process of replacing my exh. man. gasket, I managed to crack my oil return line. With some putty, tape, and zip ties I managed to get it home (with zero leakage actually...)
I have had an oil return flange for some time, and figure I should put it on. It is female thread, so I plan to take it to the store with me to find a barbed nipple for it, but I dont know what size the fitting off of the 45* adapter on the block is.
Also, I have my doubts that a std. rubber line will be sufficient with how close it is to the bottom of the manifold. The gorilla tape I used in the temp fix shows signs of melting in the very light throttle (avg'd 35 mpg) trip home...
Has anyone else gone this route? What material did you use to connect the two ends?
3rd Annual Philly Tri-State NATO Meet - http://natomessageboard.com/ultimatebb.p...p=1#000003
'87 - Range Roller 4* adv / 50 trim t04e / Ported E6 / Gutted Knifed intake / Stinger 3->2.5" / Adj. Cam Pulley / Warlboro 255
To Do: PIMP/MS2, FMIC, Bigger Inj
