I take it you are switching from an IHI to a water cooled T3? If so, the oil supply line will work, but should be replaced with a new one anyway. Oil drain line is different - different flange at turbo. Water lines are 100% different. Either get a set of water lines for a T3 from the JY, or fab up your own.
