Im kinda fuzzy on the whole HLA thing but I know they need oil pressure to properly fill up and push on the rocker arms. Would having crappy oil pressure cause the valves to not fully open?
88 5 speed TC
5.0TurboCoupe1988
Apr 2008
Broken Arrow, OK
if you have low oil pressure, the HLA's are the least of your worries...
1988 TC 2.3/5-Speed, 148K
5.0TurboCoupe1988 Wrote:if you have low oil pressure, the HLA's are the least of your worries...
I know that I was just wondering if we were in a honda/vtec scenario lol?
88 5 speed TC
Like 5.0TurboCoupe88 said........
Yes, low oil pressure can affect HLA. Are they clacking?
No mine is fine..its around 25 at idle and 50 after 2k rpm. I was just having a dumb thought if low pressure would start to affect to HP/Performance with the valves not opening. Knock on wood my car just leaks it lol.
88 5 speed TC
TurboCoupe50
Chesapeake, Va
If the HLAs aren't getting enough oil they will be causing a clattering noise, and no the valves will not open fully but unless you have a fine tuned butt dyno, would probably never notice the difference in power...
As already stated if oil pressure is low enough to create HLA noise, there are other SERIOUS issues...
