Oil pressure and plug wire pressure (long)
Allan S Offline
(should be plug wire question...got pressure on the brain I guess...)
Has anyone experienced random problems with getting oil pressue at startup? Sometimes happens after the car has been driven and everything gets warmed up, then you park to go into a store etc. and go back out and restart and pressure will hover at top of red/bottom of normal range on gauge. Then it slowly works up to the r and m and stops there. All other times the gauge reads mid to upper end of normal range. The oil is synthetic and fine (no garbage in it). It is such a rare occurance that I'm having a hard time believing it is the pump, but could be wrong...
Next: Have to get new plug wires. I've seen comments to use only oem motorcraft, and bad things said about others (bosch etc.)wires. But typically said on sites where comments made to chage oil every 2k or less or turbo wont last 50k miles (my turbo has 190k miles and still putting out 18 psi with no problems) along with other silly statements. So it is hard to put stock in those comments. Any proof to the wire claims? I have not had any problems with the Bosch wires in my 88 sport (5.0) or 4.0 Aerostar. I do know the SVO plug wires are a joke, they are on the car now and put out so much interfereance you can not use the radio with engine running so they have got to go! Thanks.
[This message has been edited by Allan S (edited 04-20-2001).]
SCMC Marketing Director
www.svtcobraclub.com
2004 Redfire SVT Cobra
87 TC RIP 10/2003.
Oil pressure: I think it is a sender problem. Mine kind of does what yours does, but doesnt drop down as low as yours. On hot shut down, the sender gets heat soaked, and its resistance goes up due to the heat. When you start up hot, its resistance is higher than it should be, which makes the gauge read lower. When my press gauge started acting weird, I got a mech press gauge, and mounted it under the hood. Used a brass T from the hardware store to attach both the factory sender and feed for the mech gauge. That way, if my factory gauge acts strange, all I have to is pop the hood and see what the pressure REALLY is.
Wires: Motorcraft always seem to work, but I have heard of a few cases where they were bad out of the box. With other brands, it is a crap shoot... some work, some dont. Right now, I have a set of Bosch Opticore wires, and dont have any problems with them. I tried a set of Bosch platinum plugs, and the sucked (bad high RPM miss). Went to stock AWSF32C gapped at .032, and miss went away.
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 20 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0: intake, exhaust, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 00 Windstar (wifes vehicle)
Nate K Offline
Yes, I personally have had problems with the Bosch wire sets! Remove only the wires and the eratic missing/stumbling disappears. I know of two other memebers that have had the same exact problems steming from the wires. I'm not saying that other brands of wires don't/won't work, they will, it's just finding one that works without any side effects. In the past I have had good luck with several Taylor wire sets on my 88TC and would use them again. Currently I have Motorcraft wires.
The problem with the Bosch set and other similiar to them seems to come from the amount of resistance in them. From what I'm told, it must confuse the TFI module.
Whichever brand you decide to go with, be sure you can return them if they don't work and if you develop problems after changing to that new brand, the very first thing to check would be removing the new wires and putting your old set back on.
90 Mustang LX 5.0L Notch
Cars I wish I still owned:
69 Coronet 440
70 Torino 351C
79 Bronco 351M/400 on 35's
79 Trans Am 403 (6.6L)
88 Cougar XR7 5.0L
I had oil pressure gauge problems on one of mine exactly like you described. I stuck a mechanical gauge under the hood and did some cold and hot readings. Everything was fine, I replaced the sender and don't worry about.
Thanks Jeff for the explanation on why the gauge is so slow on hot start.
manifolds, polished and cc'd chambers RR, Crowler, ARP head studs, Walbro 190 pump and T-3 for starters. KB subs
and jack rails
Allan S Offline
Thanks for the input! That was very helpful.
87 TC RIP 10/2003.
DennySweet Offline
Mine does the same thing, However as I was watching the oil pressure gage go crazy I also noticed the fuel and water temp gages were off a little. Maybe the resistor on the cluster is bad. The fix is on the NATO repair section! Denny
88TC,87TC,88Mustang,86S-10,82Toyota,2-88S-10Blazers,56 Merc
88TC,87TC,,86S-10,82Toyota 4WD,3-88S-10Blazers.
GT350R Offline
The plug wire thing is funny.I have seen other wires on car's and they run fine.But sometimes they dont. I is just to easy to buy the Motorcraft and not worry about it.
GT350R
84 Gt350 2.3T T-top
84 Turbo GT 418rwhp
My Garage
Noname
Guest
Yeah, been down this road with the BOSCH plug wires...STAY AWAY! [Image: smile.gif] For about $5 more, I got Motorcraft and the car runs like a scalded dog.
[This message has been edited by AC (edited 04-23-2001).]
bigep74 Offline
I agree I have learned the hard way about aftermarket parts , I had accell wires and they where crap $44.00 for the set. I purchased Motorcraft wires from Rockauto no issues
boosted chicken Offline
bigep74 Wrote:I agree I have learned the hard way about aftermarket parts , I had accell wires and they where crap $44.00 for the set. I purchased Motorcraft wires from Rockauto no issues
Holy 16 year thread revival!!
I will say I have had great luck with Magnacor wires. Kind of expensive but lasts a lot longer than a carbon core type wire.
88 TC#1 Boport stg 3 alum dport head, PT6466, Boport header, CP pistons, Crower rods, MS2xtra
