oil leak
jeffg Offline
pulled in the garage and seen a puddle of oil on the ground thinking no i couldnt be leaking like that well i was,but it looks like it coming from around the cam sproket is there a seal in there that could go?how hard would it be to replace any info would be great jeff
1987tc Offline
If the cam seal is leaking you will have to pull the cam sprocket off to change the seal. It is not hard at all to do. You can use a flat blade screwdriver to pry out the old one then gently tap the new one in. I use a little assembly lube on the seal where it meets the cam to prevent hurting it while installing.
Wes
1987 TC:
Hurst compition plus shifter,K&N cone,rollor cam,custom single exhaust,Gillis valve,H&R springs,KYB shocks,struts and quads.
3.73 rear. lots more to come!
Linton Indiana
