oil leak
justinef'npartlo Offline
two days ago i looked under my car and there was a few oil spots...i checked the oil and it was low so i put a quart of oil in the next day there was a large puddle about a foot in diameter. if anyone could let me know what could be leaking it would be greatly appreciated...... oh its an 88 tc if that matters
stock 1988 T Bird Turbo Coupe, 5speed, Dark blue, Grey interior.
84TBirdTurbo42 Offline
rear main seal, valve cover gasket. oil line, oil filter, drain plug.... theres a million places it can leak oil.
Chris Perry
It might help to get it up on a lift and start looking. Like Chris said there are lots of possibilities. Sounds like you have a significant leak so don't ignore fixing it and very regularly
check the oil level.
well i checked it a little bit ago and the leaking slowed down a lot, its back to the few spots here and there
Cracker137 Offline
Make sure it isnt comming from the oil level sensor, I just took mne out and put some teflon on it and boom no more oild leak. But like 84TBirdTurbo42 said it can leak from many diffrent places.....
1987 Thunderbird TC
-T3 Turbo
-K&N
-3G 130 Amp
zbird Offline
Could be from the middle of the sensor and teflon will not stop it. They are notorious for leaking from the center around the sensor when they age. The sensor is still available from Ford. Try cleaning any oil off the engine then running it and rechecking for the culprit.
Dom Z
99 F150 4x4
14 Ford Escape 2.0L Turbo
RC Martin Offline
The worst intermittent leak I had was the seal around the oil cooler. It would leak little more than a couple drips one day, or let out a steady stream other days. 23 years (that's how old it was at the time) is a long time for a rubber ring that gets heated and cooled, and holds out oil...
thanks for the info guys
Good idea... the oil level sensors are well known for both leake from the sensor itself and leaks from the gasket.
well the leak seems to be because the crankcase was clogged causing pressure that blew out the rear main seal and pretty much all the other seals and gaskets on the engine......
