Jarron
Jul 2008
Jonesboro, GA, USA
Does anyone know where I could get or have an oil feed line FITTING from the turbo to the line for a T3? To be more specific, its the MAX PSI SS Braided line. I did not want to have to buy a new line just for the fitting. I got the rebuilt turbo back from Charlie down there at EVERGREEN and it looks great! Just cant wait to get it on the WarBird!
1987 TC aka BIRDPWR - 5 Speed - Silver / Raven; NEW MOTOR!, .48 T3/4 Stage II, BOV, Gillis BoostValve,K & N Filter, MSD Ignition, 3G Alt, HID 8000s.
NEXT UP: 3" DP, 255HP fuel pump, AFPR, larger injectors, FMIC
Use of a new line is recommended. Many places won't guarentee a new turbo or a rebuild if a new line isn't used, BTDT, got the fried turbo
Have you tried like the plumbing dept at a major store - Lowes, for example. Or try Grainger or check with the turbo shops
Jarron
Jul 2008
Jonesboro, GA, USA
the line that i have is new, I just seemed to have misplaced the fitting that connects the line to the turbo. Just needed to know what it was called and what size it was.
thumper
Jun 2001
Dexter, MO
Scott at MaxPSI will send you a new one, I bet... probably for free. He's a cool dude.
A.K.A. Corey Bennett
Robert Camp
Jan 2006
Raleigh, NC
The MaxPSI fittings are AN, not the stock inverted flare.
Robert Camp
Jarron
Jul 2008
Jonesboro, GA, USA
Yippee!! I found one at ACE Hardware! 1/8NPT x 1/4 flare! Now, all I gotta do is get that blasted factory oil line off! Whats the easiest way?
Use a line wrench. The only way to go to keep from rounding it off.
Jarron
Jul 2008
Jonesboro, GA, USA
I got it off. I had to cut the line near the sending block, and then beat/bend the remaining line so that it cleared the first bolt of the intake. Just took the whole sending block off. Man o man.
Ryan H
Oct 2004
Panama City, FL
Yeah, I had to hack my old one up as well. I used a Dremel tool and cut it in various places to facilitate moving things easier.
xcrunnerbd
Oct 2006
Woodland, MI, USA
I kept mine intact. I don't know why really because I'll never go back to it. I just didn't want to cut things up I guess!
Project 13 sec. / 30mpg in '88 TC 5Speed : [email protected] / 32+ mpg
On The Car: KN cone, 2-stage [email protected] 15psi wired to fuel switch, Kirban AFPR @ 39psi, Walbro 255 HP FP, 130A 3G Alt., Full 3" Stinger Exhaust incl. cat. no muffler,
Shelf: .48 T3, ported E6, BPV
