In the middle of rebuilding the engine.
I have come to the point of putting the oil cooler back on and have decided to either delete it or change it to a sandwich and add cooler up front.
Would have liked to put it back on, but not excited about that, since engine had 200k and i don't have much history on that 200k.
I know a new one is pretty much out.
So has anyone put a sandwich in and run through an automatic trans radiator on a 5sp? Kind of be similar approach, right?
I'm switching to a new turbo that doesn't have water cooling. Not sure if that makes a difference.
Thanks,
Adam
88 black bird.
A sandwich type adaptor and external cooler should work. Just be sure the sandwich isnt any thicker than the stock cooler or you will have trouble getting the oil filter on/off due to interference with the steering shaft.
The stock oil "cooler" also warms the oil much quicker after a cold start. In other words the stock "cooler" is really a oil temperature to coolant temperature equalizer. You may want to consider a thermostatic valve that bypasses the external cooler until the oil warms up to 180 deg F or so, especialy if you live in a cold climate. I have seen these valves online, but cant remember where I saw them.
OK thanks. The warming thing is why i thought about running it through the automatic trans ports on the radiator, i have generic radiator with those ports, but car is 5sp. I have now read that the flow probably isn't good enough to do that, though.
I also read something that said routing the oil external isn't a good idea on stock flow volume pumps. I am putting back a stock flow pump, because of the issues I've read about the aux shaft and dizzy gears. I have ordered the esslinger billet shaft and gear, still waiting on it.
I know some have just deleted the stock cooler and not put anything back. Is this my best option?
I live near atlanta, it's hot most of the year. I doubt I'll ever over cool the oil.
Thanks,
Adam
