One more question, it looks like there is a small oil leak from the oil cooler. I guess I will try tightening it but I heard it is discontinued?
Can I get a gasket or seal and use the old cooler with new seals?
Does the cooler just twist off like the oil filter does?
Fixing all the leaks has been a real battle. So far I have done rear main, crank seal, cam and aux seals, and VC gasket, along with a new sender. I went from about 30 small puddles to around 2! lol
2.3L Turbo in 88 stang, browntops, 93 a4ld, volvo ic, broncoII rad, gillis valve set @15, k&n af.
