wrightsvo
May 2012
Orange, TX
with the spout disconnected and timing light connected, everything acts as it should.
With the spout in,however, when any throttle is added, there is a sporadic skip in the timing light. It does the same with the timing light clamped on the coil wire.
Please advise /inform.
1988 ASC McLaren
Not B Anymore
Nokesville, VA, USA
Does it not run right or is it just the timing light that's skipping?
wrightsvo
May 2012
Orange, TX
It has a random slight miss under acceleration. That is how I got to find this.
1988 ASC McLaren
Possible failing TFI. Do you have a spare TFI, or a whole spare distributor you can try?
wrightsvo
May 2012
Orange, TX
I do not. I came here hoping to find a recommendation before I started randomly throwing money at it. I suppose the TFI would be the best One to start with?
1988 ASC McLaren
wrightsvo
May 2012
Orange, TX
Also...my TFI has been relocated off of the distributor.
1988 ASC McLaren
wrightsvo
May 2012
Orange, TX
Installed known good working distributor with tfi. Also installed known working coil. Condition persists.
Is the ECU a possible culprit?
1988 ASC McLaren
wrightsvo
May 2012
Orange, TX
Or any other ideas?
1988 ASC McLaren
Could be a lot of things. Have you pulled the codes? How fresh or old is the tuneup and what brand parts used? Are the plug wires crossed in the loom? Cracks in the dist cap?
Check the harness between the TFI and the PCM for damage, and to be sure the foil like shielding is in place. Also be sure the SPOUT connector terminals are clean and the connection is tight. It is possible this is a PCM problem, but, IMO, this is unlikely.
Does the timing jump around at idle? It should.
