Well, for the most part, my car idles fairly well, usually around 900- 1100 rpms, but for some reason, sometimes, the car will just start idleing and 1500 rpms. I can however fix the problem, by shutting the car off real quick, and firing it back up. and it will idle normal.
Also, ive noticed, if the car is hot after a drive, and if i stop for about five minutes to a store, or something, and get back in, it wont idle good at all, usually about 600 rpms, and it will usually stall.
Could this be a computer problem?
Because sometimes, when i shut the car off, and refire it up, it seems to run totally diffrent, sometimes good, sometimes not as good.
Never had a problem where i couldnt drive it from this condition, it just seems that sometimes, the car has more power, then other times.
Thanks,
Chris.
Btw, 1984 with a T5.
Thanks,
Chris.
Chris Perry
