Obvious problem but I can't seem to solve it...
Screw-Rice Offline
Due to recent problems with the car I am slowly going insane. I fixed the whole blowing fuses, engine fires problem, but now I have a new one. I replaced the negative battery cable and bought a new end (for additional wires going to the battery) for the cable and tightend it down and the friggin thing broke in half > [Image: frown.gif] . Well I tried starting the car and all it did was click (alternator) well I grabbed the original end off the old cable and put it on. And it does the exact same thing than slowly (about 3 hours) the battery is completely dead. I can put my jump pack on and start the car immediately. But even after I drive it as soon as I kill it and try to re-start it I get the same clicking. While the car was running I removed the negative cable and the car remained running so I ruled out the alternator. Could my battery of finally cashed out or am I missing something completely obvious? The other cable that goes in the end along with the battery cable to mount to the post is corroded but I am not sure what that one does. I know I missing a completely obvious problem but can't seem to answear it.
Rice never knew what hit them.
Why don't you take th ebattery to a parts store and have it tested. Do the easy stuff first. Many parts stores can test batterys and alternators.
Screw-Rice Offline
I am doing that tomrrow, and to be honest I am hoping it is the battery because it justifies buying an optima red top Wink
Noname
Guest
Did you clean up the terminals / end connections on the cables before attaching them? I used to have corrosion problems on my negative battery terminal ALL the time until I started using some special coating I found at Pep Boys.
1987tc Offline
Pulling off the battery cable does NOT tale the alternator out of the picture. As a matter of fact I cannot begin to count the number of alternators that have been sold because people did that. When you put the cable back on it sends a spike through the system that has a nasty habbit of popping the diodes in the alternator. Another sign is the fact that it discharges while sitting. If the diodes are popped then it will discharge when ever the car is not running. It can still charge just fine while running but will discharge when sitting.
Wes
Screw-Rice Offline
The connectors are new and the terminals are clean. I will have the alternator and the battery checked and see whats going on.
philS Offline
I would try a spare (or different) battery to see if it discharges as well. If you have a voltmeter, I would take a look at what is happening with the engine running (alternator charging the battery) and with key on, engine off (to see if there is additional draw on the battery, other than the small draw from the clock, computer, radio memory, etc.)
86 TC, 73 Austin Mini
Click here to beat a ricer.
Screw-Rice Offline
I'm going to borrow my brothers voltimeter to check the charge of the battery, how do I check and see if the alternator is putting out properly at home instead of taking it to autozone?
You need to get the battery tested under load. If the alternator is putting out anything it will show by checking the terminals of the battery with a voltmeter, but that does not tell you if the battery is accepting the charge.
Screw-Rice Offline
Alright I am just going to pull the battery and get it tested down the street. Anyone running an optima battery, I have a friend who has one and swears by it, anyone else have good/bad opinions about them?
