O2 sensor
turbobirdsilver Offline
I havent pulled codes yet, but when i upplug it nothing happens. What should happen?
Ray
Could you be more specific...... unplug what from what?? What problems are you having? Please describe in detail!
88 Turbo Coupe: Intake and exhaust mods, T3 turbo at 23 psi, forced air intercooler, water injection, bypass valve, Ranger roller cam, subframes, etc., etc.. // 86 Tbird 5.0 (original owner): intake, exhaust, valvetrain mods, 100 HP nitrous, ignition, gears, suspension, etc., etc.... // 91 Escort: Bone stock winter car // 04 Taurus Duratec (wifes car)
im not have any problems, the car runs fine. Just as a test i uplugged the 02 sensor (the connecter on the end of the wire) and the car didnt run any different. My dosent have any "check engine" light (its a 83) so i dont even know if it would give me one. I guess i'll have to pull codes from it.
Ray
If the O2 is disconnected, the car will still run, but will likely run rich. It may run a little rough every now and then, but it shouldnt die. If EEC doesnt see an O2 output, it just reverts to a fixed fuel map. If you had a CEL, it would be on with the O2 disconnected after the motor warmed up.
