My 1983 turbo coupe just got a Boport head along with a gnari turbo kit. My main concern is how much power I can run through the non world class t5. I plan on nothing more than 300hp for a while but will eventually want to replace the trans with something that will withstand more power. Any help appreciated.
Thanks for the reply! I guess I’m gonna have to find a new trans... I haven’t found too many options other than the t56, and the tko 500 and 600 but can’t justify spending over $2000 on a transmission. Are there any cheaper routes while safely putting out over 400lb ft?
anasazi4st
Feb 2015
Phoenix, AZ
Yes according to the chart a stock T5OD—even World Class—can’t handle that much torque, only 240 ft/lbs. I’m sure with some modifications you could probably get to 300-305, but that sounds like the top end.
firebirdparts
Dec 2017
Kingsport, TN
To me, it's totally worth $2000 for a transmission, if that is what you want. I mean, a rebuild for a Chrysler minivan would still be $2000. Right? It's a bargain. I know that doesn't help, ha ha.
andrewjs18
Aug 2012
Philadelphia, PA
I'll be in this boat soon enough too, I'm sure. My TC is probably close to 275hp or so as it is now and I recently picked up a pimp ecu, 1.9 boport cam, 80# injectors and such for the car. I'm hoping for about 330-350 HP.
