freebyrd
Sep 2005
Angola, NY
Ok i just recently put my 87 TC on the road. It seems that it doesnt have all the power it should have. When i drive it, it feels like the car has a sweet spot. When i push the pedal all the way to the floor, it really doesnt feel like the turbo is working, but you can hear the turbo and the gauge says 15lbs. If i back the pedal off alittle bit you can then feel the boost, but the gauge only reads 5 lbs. It feels like it wants to go but you can feel a miss in it as well. Kind of like a surging or something is holding it back. I put new plugs, wires, fuel filter, coil, cleaned iac, Tps is set at .97 alittle high but that thing is a pain to adjust, got a K&N in the mail as well as new cap, rotor, PCV valve. It has some old gas in it but i filled up with 93 so that should even it out. I checked for air leaks around the IC but couldnt find any. What should i check next? Thanks
How well did you check for leaks? Did you take the hoses off and squeeze them, looking for cracks. Sometimes cracks open up under boost and otherwise it's very hard to see them. What you describe could be a boost leak
JohnL
Jul 2005
Madison Heights, VA, USA
If the cap and rotor isn't on yet, wait on that and see. But also boost leaks like Pete said. Take the hoses off and squeeze them to see if they have any splits. Also check the VAM hose to see if it's got the spring in it to make it stiff, it could be collapsing.
John Lewis
88 TC, 87 XR, 84 SVO
Currently deciding which is worth my time.
freebyrd
Sep 2005
Angola, NY
Well the cap and rotor wont be here until saturday, but i will recheck the hoses.
slacken00
Jun 2001
waynesboro pa
also check your timing and make sure you take the little pill out when you set it i had that problem and remembered 2 days later that i forgot to take the pill out and took it out reset the timing and away it went, the turbo would spool up the gauge would read 15 or so lbs. and it just wouldnt go any faster that was my problem
88 tc black, sc50, stinger 3 inch ex, 255 lph fp, kirban afpr, bov, ported big valve head w/a237 cam, gutted upper intake, (knife edged lower, 75 pph inj. not on yet), spec 3 clutch, street tires best run 13.9, best mph. 109.5(no tuning)
http://s186.photobucket.com/albums/x147/...t=1073.jpg
2008 ford edge sel awd
2000 ford mustang gt,exhaust intake chipped
Disconnect your knock sensor.
No
freebyrd
Sep 2005
Angola, NY
Alright guys i went out today to check my timing and i realized that the timing marks were on that plastic cover that i only have half of. So will this work, if i set the crank at #1 TDC then put a mark on the block and crank pulley. Then with my timing light set the distributor 10* BTDC, because i can retard the flash on my light.
slacken00
Jun 2001
waynesboro pa
i dont really understand what your saying maybe someone else will but make sure you are at tdc and the #1 piston is at the top and not at the bottom b/c i did that once forgot the check the piston and make sure it was actually at tdc, i just went through all this stuff for about 2 months but i got it finally
Should work.
freebyrd
Sep 2005
Angola, NY
Ok I was at the local junkyard today looking for some little odds and ends for the TC. Well i walked by this 88 mustang and seen that it had the 2.3l in it. So i grabbed the plastic cover off with the timing marks on it. THis cover should have the same marks as the TC cover had right? If so i will just use that one.
