Norwalk
rv23tc Offline
Norwalk opens on Friday,Anyone going? there is a swap meet on Saturday. weather is suppose to be nice.
14.7 @ 90mph
mods: 260 armstrong xp pump,430gears,86 GN turbo,boost controller,9mm motorsport wires
boost gauge, air/fuel
mods: 260 armstrong xp pump,430gears,,boost controller,FPR,9mm motorsport wires,K&N filter
I might go out Sat for the swap meet. is it a ford type meet or everything?
jeffg Offline
im going sat for the swap meet,pete give me a buzz if you want to go together
Ohio88TC Offline
Or we could all roll up like the show meet
Jeff, I may take you up on it if I can't find this vacuum leak problem. Got everything else ironed out, I think. Got a whistling noise that gets louder as the rpms increase and it appears to be affecting the A/F ratio towards lean (make sense). Going through everthing now. Keep you posted.
GT350R Offline
I was thinking about going but they said the weather is supposed to be in the low 50's and rainy.
This is a different one then the "Fastest street car shootout" right?
GT350R
84 Gt350 2.3T T-top
84 Turbo GT 418rwhp
My Garage
jeffg Offline
If im not mistaken it is the fastest street challenge.someone correct me if im wrong
rv23tc Offline
Friday is just test and tune. Sat. is a swap meet for everything. just curious are any of you guys going to race your cars??? or are they just for show? i read all these mods. it would be nice to see some t-birds at norwalk......
14.7 @ 90mph
