No start after running rough
nunnaro Offline
So I own this 88 for about 6 years and as strange as it may seem, I never put my foot all the way into it and wind it out. The other day a guy came up on me like gangbusters and I put my foot into the radiator. The first thing I noticed it boosted over the 15 lbs almost instantly. No problem getting away from him but I came off the high boost. I looked under the hood when I returned home and found what looks like a bypass of some kind. Maybe a few days later I started the car and after driving a short distance the car started running rough and lost pretty much all power. I turned around to bring it back home and just before reaching there it started to run fine. I parked it anyway and when I got out it was smoking at the rear of the firewall area on the passenger side. I left it alone. No fire. Nothing obvious or anything except for the smoke. Now it won't start. Tries to. But won't start. Anyone with any ideas?
dolphin1 Offline
So how does it crank, like normal or does it seem funny. Need to check the cam is still lined up right. Put it on TDC and pull the plug in the belt cover and look at the marks. Also make sure the cam belt is still there too and the cam turns. Leak could be valve cover or coolant. Pull the intercooler and look. You could do a compression test too to make sure things are good.
Mike
Just one white Turbo Coupe now
nunnaro Offline
(09-29-2024, 10:42 PM)dolphin1 Wrote: So how does it crank, like normal or does it seem funny. Need to check the cam is still lined up right. Put it on TDC and pull the plug in the belt cover and look at the marks. Also make sure the cam belt is still there too and the cam turns. Leak could be valve cover or coolant. Pull the intercooler and look. You could do a compression test too to make sure things are good.
So I've been away all week and tried to start today. Wants to start but doesn't. Cam belt is fine however there is a noise from the rear (assuming the fuel pump) that's intermittent not the
prime cycle. I guess it's fuel pump time?
Mikey97D Offline
Fuel pump only turns on for a few moments when you go to start.
Do you have a timing light that you can put on to make sure you have spark? Does the car smell like gas after trying to start it?
dolphin1 Offline
so you say the belt is fine, did you look to see If the cam gear is lined up on the timing marks when the crank is at TDC 0degs. noise at the rear, of the engine or car. you might check the fuel pressure.
Mike
nunnaro Offline
Thanks Mike for your response. I found out since your last post that as strange as it may be,it seems as luck would have it, the fuel pump went at the same time the trouble started. So it's change the pump time. Thanks for your input!
dolphin1, Mikey97D and Jeff K like this post
Good time to upgrade to a 255 liter per hour Walbro pump!
