No Reverse Lights
Cerebral Offline
I just got to work, and noticed that neither one of my reverse lights are working. Where is the sensor for it? Suggestions?
1987 Automatic TC- parts car
1987 5 Speed TC, K&N on Vam,Boost controller, T3, Bob's Log, Stinger 3 inch exhaust with Magnaflow, FMIC, Forge Dual Piston B.O.V., Ranger Roller, Esslinger Adjustable Pulley, Boport Drop in Valve Springs, Pyro Pete Clutch
Scott Mabe Offline
If your turn signals also do not work then It is most likely a blown fuse, if that's not it iirc the sensor is toward the rear of the transmission.
1987 Turbo Coupe
1990 F-250HD 460ci
Check the easy things first. Are you sure both bulbs arent burned out?
Cerebral Offline
Light bulbs check out. Turn signals work, is there a test for that switch?
