slowbird
Aug 2005
Ann Arbor,Michigan
I just got another turbocoupe yesterday that wont start.I checked all that I can without having a wiring diagram.So heres the deal=No power to coil,think its bad ign.switch,already changed eec.Is there anyway to check or bypass ign. switch?
84 Capri RS TURBO T-top
1988 Tc (mangled beyond repair)
1969 Cougar
Check your email.
Easy test: Jumper coil pos terminal to batt pos terminal. See if you have spark / car starts. If it doesm ig. sw. is bad, or circuit from ig. sw. to coil is open. Not 100% sure, but I think these is a fuse link in this circuit. I am at work, and cant check my EVTM to be sure.
Ryan H
Oct 2004
Panama City, FL
I had a fusable link go bad that caused a no start in my last car. I'll try and dig up my post.
Ryan H
Oct 2004
Panama City, FL
Nevermind, mine wasn't the one to the coil power, it was to the starter and such. But check the fusable links by the battery anyway, can't hurt!
slowbird
Aug 2005
Ann Arbor,Michigan
I was gonna try to jump the coil but I wasnt sure if it would burn anything up.thanks for the help.i got shipped down south today with my job so ill try this next week when I go home.
1969 Cougar
EEC IV / TFI ignition systems dont have a resistor in the coil power lead like the "old days" of points and condensers, so no damage will result jumpering the coil right to the batt.
slowbird
Aug 2005
Ann Arbor,Michigan
Jumped the coil today.Made a pop noise and started to spark for a second then stoped.now theres power to the coil without the jumper and still no spark= even tried a differ coil.any ideas?
1969 Cougar
DonH
Jun 2002
Central Massachusetts, USA
You have to explain more of what you've done. Is there power at the coil with the key on in both run and start? What did you change when you changed the "eec"? How did you test for spark? Have you looked at the ignition switch?
1987 TC stock except ATR 2.5"
1983 Pontiac Transam T-top 5.7 T56 [email protected] top speed: 176mph
slowbird
Aug 2005
Ann Arbor,Michigan
Sorry for all the crap.today i pulled down the fuse block.Looks like the previouse owner played slice and splice.last question.How hard is it to replace the fuse block.Ive got all the parts in a parts car.
1969 Cougar
