trashline
Feb 2005
Levittown, PA
ok i finally got around to checking why the abs light is on. well as i was advised to check to see if power is oging to the unit and it is not. they told me to check light green / yellow wire and i had no power. is there a fuse for the unit?
second im getting a fuel smell when i idle during driving and when i turn the key on but dont start the car any thughts? thanks
1966 mustang
1988 tbird
JT
The light green/yellow wire at the ABS computer is simply a ground. Make sure it is getting a good ground.
Also check to make sure that the grey/yellow wire at the ABS computer is seeing a positive 12 volts when the ignition key is ON.
trashline
Feb 2005
Levittown, PA
i dont have a grey and yellow wire
1966 mustang
1988 tbird
JT
i double checked to make sure. It is a grey wire with a yellow stripe. That wire supplies the ABS computer with +12 volts from a fuse link. If you don't have that wire at the ABS module, that would explain no ABS operation and the lamp being on and unable to retrieve any trouble codes.
The grey/yellow wire should be in the Pin 18 slot at the ABS wire harness. It is possible the colors are slighty a bit off in shade. Maybe it's me, but not all Ford colors are 100% true to my eyes.
trashline
Feb 2005
Levittown, PA
ok pin slot 18 should help me a bit mroe. when i get out of work i will take a better look.
any idea about the gas smell?
1966 mustang
1988 tbird
JT
Where is the fuel smell coming from? Under the hood or near the fuel tank?
Common leak points under the hood would be the tops of the injector bodies (brown plastic). Over time, they can develop leaks that only replacing the injector can resolve. It is possible that the top "O" ring between the injector top and fuel rail have a developed a leak, which can be fixed with an "O" ring kit. It's not always easy to see exactly which of the two problems you have in either of those two cases. Turn the key to ON and look at each injector top to see any small fuel leak.
If the smell is towards the fuel tank, the supply and return fuel lines that are a part of the fuel pump assembly mount for the fuel tank are prone to rusting and leaking. i'd think you would see some fuel on the ground or on the side of the tank if you had a leak there.
[This message has been edited by JT (edited 06-05-2005).]
trashline
Feb 2005
Levittown, PA
im not sure where it is comig from. but i havnt seen any leaks on the ground. should the injecters be able to move in there palce? b/c i was able to spin one of them? i will have to take a better in depth look at the injecters. but they all look very clean. i really appreciate your help. and i wil get back to you about the grey and yellow wire. thanks
1966 mustang
1988 tbird
JT
Also check the fuel pulse dampener for any external leakage, which has also been a leak point for other people. See picture in link below for the location: http://www.tbirdheritage.com/misc/fueldampener.jpg
trashline
Feb 2005
Levittown, PA
ok back two injecters look wet and the abs wire isnt grey it is red and green for me and it is getting power ( which is the 18 prong)
1966 mustang
1988 tbird
trashline
Feb 2005
Levittown, PA
JT im gonna use your troubleshooting setup on your site. i hope this will be able to fix the problem thanks
1966 mustang
1988 tbird
