No power through Selnoid? bought 3 new ones
qmakowski Offline
i have no power going threw my selanoids. i bought three new ones, all they do is click. the car wont start. i replaced the starter cable too. all i get is about 3 volts. everything going to the selanoid checks out fine. just no power going to the starter! help!
Chuck W Offline
Umm...have you checked the starter out?
DO you havce 12V going to the solenoid?
DO you have 12V from the Ignition switch in the "Start" position?
Have you checked the ignition switch?
83 Pseudo-Coupe, 87 Ranger (soon to be 2.3T), 84 XR7, 86 XR4 and 62 Mercury Monterey (old n slo)
qmakowski Offline
starter good
12v to soleniod, good
12v to switch, good
on start, good
no power going through, bad
rairbird Offline
Have you checked the engine ground, or made sure that the starter is grounded? This happenned to me and drove me crazy as well. The starter wasn't exactly tight so there was not sufficient ground. Just a thought.
87 T/C, 5sp., Ported/Polished head, 1.89, 1.59 S.S Valves. Motorsport Lifters, A-234 cam, ported lower intake and E6, 3" DP, T3/T04E 46, Gillis BCV, K&N Air Filter, 42LB injectors, kirban Adj. FPR, Walbro 255 FP, Diablo chip, Head and Main studs, APR rod bolts.
88 T/C stock, 5sp.
Chuck W Offline
Yup, check out the grounds or the starter itself..
