Stan B.
Dec 2005
Piqua, O.H. 45356
Well finally got out to the track tonight,just could not get that d##*nm 14.9,having major traction problems.Rear tires are 245/50/16's,in decent shape.OH!Well,here are my times.
1st run 2nd run 3rd run
React..4900 1.029 .514
60Ft.2.298 2.239 2.121
330ft.6.5500 6.460 6.339
594Ft.9.3200 9.213 9.102
1/8 9.949 @ 71.44 9.84 9.71
1/4 15.30 @ 88.62 15.16 @ 91.67 15.06 @ 92
88 Turbocoupe(maroon)Stock
96 gt mustang...CAI,Trickflow plenum,H-pipe,flowmasters,UDP,70mmTB,3.55gear
Sluggo
May 2004
Huntingtown, MD., USA
You're very close though. Looks like one more run would have been it the way the times drop with each run.
Doug
86XR7auto
Mar 2003
Mt. Pleasant, MI. USA
Hey Stan
Your TC looks like it is laying down of the last part of the track. Do you have an upgraded fuel pump? Looks like you had fun anyways.
Travis
Stan B.
Dec 2005
Piqua, O.H. 45356
It has the walbro 255,Holley AFPR,GarretT3 (.48-.60)Ranger Roller,K/N,Front mount I/C, T5,3.73 cogs.Boost is approx. 18 psi,FP is 40 base,timing is 10degree base.Also i was running two gallons of race fuel (mixture) 92 octane.
Sluggo
May 2004
Hmmm. What was your 1/8 mph on the last run?
Doug
Stan, try a little more ignition timing like 12 to 14 degrees, maybe even more if no detonation. Nice improving progression on those runs.
You coming to the Dayton picnic on Sept 30th.
Stan B.
Dec 2005
Piqua, O.H. 45356
Sluggo,my 1/8th on my last run or best one,was a 9.71 @ 73.7 mph,and yes i will be at the pic/nic on the 30th Pete,see ya" there.I'll probably bring both of them also.
Next time out,i will try the timing adjustment.I,m also thinking of going back to the stock cam also
