No Brights
TCLover82 Offline
This is an Auto-Lamp and Auto-Dim equipped '88 TC.
Have been having this problem for awhile. My Brights will only stay on if I hold the switch lever back the entire time, let it go and they go back to Dim. I replaced the Multi-Switch on the Column expecting it to be resolved, but it still does the same thing as the previous switch did. It's like something won't allow the lever to stay engaged once you pull it back, and I'm now thinking it has something to do with the Auto-Dim setup.
I unplugged Both the Sensor in the Dash, and the Sensor hanging from the bottom of the rearview mirror, and nothing changed. Anyone here had this problem before?
'88 Thunderbird Turbo Coupe - 120K miles, 99% Rust-Free, 351W/AODE Swap coming soon!
TCLover82 Offline
Anybody have a clue as to where I should start looking next, to get my brights to stay on without me having to hold the lever back constantly?
Not B Anymore Offline
So if you turn the auto-dim wheel all the way to "off", it still exhibits the same symptoms? I was thinking maybe it's a short in the wiring for the sensor, but turning the auto-dim wheel to off should release control of the high beams from the auto-dim system altogether as far as I know. It's acting like the system is on and you're trying to turn on the high beams with light shining into the sensor.
natmac3 Offline
i'd start with the senitivity adjustment wheel / switch.
bypass it into full-off & try the brights then.
1987tc
TCLover82 Offline
Yep, the auto-dim/lamp wheels where the first thing I tried, turning it to off it has no effect whatsoever, neither did any other position. I definitely believe it to be the Auto-Dim system doing this though. Like you said it's acting like someone is shining a light into the sensor, even when there's no sensor connected anymore...
How exactly do I Bypass the Adjustment wheel/switch? Just unplug it?
longbedGTs Offline
FWIW, mine does the same thing and it does not have the auto dim feature. Pulling the stick back to turn the brights on, it "clicks" but doesn't hold. I haven't investigated into the problem in the 8 years I've had the car, but suspect it's some internal switch that has gone bad. Maybe a part of the multifunction switch or the switch itself. Confusedhrugs:
88 TC 5spd~money pit
88 TC 5spd~78K miles
TCLover82 Offline
Strange that yours is doing it without even having the auto-dim feature.
I've already swapped in a brand new multifunction switch, and it still does the same thing, clicks the brights on, but will not hold the brights on. I didn't see any other part to the system when I was in the column. Just the headlight/turn signal wiring harness going into the multifunction switch, and the lever coming out of the switch itself. The switch just bolts onto the column. I don't know what else would cause the lever to not hold itself back. This is some strange stuff. Can't even drive my car safely at night anymore...
Possible bad MFS even though it is new? Replaced my MFS a few years ago due to a minor problem, and the NAPA replacement was worse than the original one. Returned it, got another, and it worked fine. Outsourcing everything to China = low quality parts, even supposedly "high quality" ones.
5.0TurboCoupe1988 Offline
isn't the auto dimming sensor on the back of the rear view mirror? maybe try jumpering it?
1988 TC 2.3/5-Speed, 148K
TCLover82 Offline
I guess I'm stuck with this issue then, since no one can seem to figure it out, including me or anyone I know. The MFS was a brand new OEM replacement, and I can't take it back for a refund. Not looking to pay $50 for another one, just to have it do the same thing, and **** me off even more at this car.
I will try jumpering the auto-dim sensors wiring harness, but I have no clue what wires to cross, and can only guess.
