Ricky03
May 2004
Bumpass, Va. U.S.A.
I picked up a wet NOZ nitrous kit but it doesn't have a wiring or install instructions. Does anyone have a copy. I would think any wet kit install would be close enough.
Thanks, Ricky
Easy..... +12 V source hot in run to arm switch on dash (indicator light optional). Arm switch to some kind of switch on the throttle linkage (a microswitch with a fabbed up bracket works well) that only closes when @ WOT. There are controllers that do this that work off the TPS voltage, but expect to pay $$. WOT switch to 30A relay coil. Other side relay coil to ground. +12V, best directly from battery, to 1 relay contact. Other relay contact to N2O solenoids wire. Other soleniods wire to ground. Polarity (+/-) doesnt matter for relay or solenoids.
georgechard
Mar 2003
villa rica ga usa
Go to Zex.com they have alot of info on there site.
