Hello guys and gals, my name is Scott and I’m from Bowling Green Ky. I own my own HVAC company and recently a customer gave me a 1987 Ford Thunderbird Turbo coupe. The engine and tranny had just been rebuilt, but not in the car yet. I got it home and installed the engine and tranny. But am having a hell of a time getting it running. I drag race and have been a gear head all my life. I am currently 44 yrs old. But this thang has fought me the whole time. It has set for 7-10yrs. Anyways it will start up but as soon as I let off the start position on the key it dies. I have replaced the IRMC, the ignition switch, new fuel pump, the fuel pump relay, and ignition coil. I read the diagrams on this sight several times and done as it told me. But I’m at witts end. Please help. Prolly something as small as wired wrong?? But man I’ve looked at it so much I’m going cross eyed. Please HELP. Thanks I’m advance.
Kuch
Sep 2016
Manlius, NY USA
Hello Scott, welcome to the forum, lot's of great knowledge on here, let's see if we can help you out. you may want to start out by pulling the codes as found on the tech articles section here, https://turbotbird.com/forum-tech-articles?page=2 . Is the car a 5 speed or auto? Was the wiring hacked up at all on the car? Engine bay harness still stock? This will help narrow it down a bit. I am not a wiring issue fan and I dread trouble shooting wiring, but maybe check power to the coil and the TFI on the distributor with the key in both start and run. Disconnect the coil wire so it doesn't actually start, but cranking so you can check power at each item.
Jeff K and Turboscott like this post
10-19-2021, 10:21 AM
(This post was last modified: 10-19-2021, 10:22 AM by Turboscott.)
Thanks so much Kuch, it is a 5-speed one owner car, not hacked wiring at all. Car looks 100 percent original. And I will try what you told me, I appreciate your reply buddy, and yes there is all kinds of great info on this site. Love the support. Were you located sir? I will let you know the outcome. I have tried to follow all instructions on here to the T. But I’m not the smartest lol.
Kuch
Sep 2016
Manlius, NY USA
One thing with these newer cars is all of the wiring that goes in them. There are many on here that are way smarter than me on these cars as I have gotten great advice on many occasions. I'm located in Central NY, Syracuse area.
Turboscott likes this post
It sounds like you're losing power to something. Did it do the same thing before you replaced the ignition switch? I've had the same thing happen in the past but usually it's in the switch.
I remember one situation where the switch worked correctly in both start and run positions but there was a slight break in continuity when going from start to run. That break was enough that the ECM lost power and would restart itself so the engine would die.
I agree with kuch, I would start by seeing what codes you can pull and hopefully that will point you in a direction.
So does anyone know exactly what wires go on the starter solenoid? Cause as I said before the motor was out of the car and I may not have the right wires on it. Thanks in advise guys, y’all are by far the best.
Also is there supposed to be a wire that goes on the I ternminallof solenoid?
And I can’t get it to pull any codes at all. I checked the ground by the turbo already.
(10-26-2021, 01:53 PM)Turboscott Wrote: And I can’t get it to pull any codes at all. I checked the ground by the turbo already.
Orange wire attached to the turbo inlet is the O2 sensor ground. That will not stop the PCM from outputting codes. Often failure to output codes or meaningless codes are an indication of an internal failure in the PCM. Often when the PCM fails, the engine cooling fan(s) and fuel pump will run continuously with the key in RUN.
How are you trying to pull codes? Jumping the pins on the EEC TEST connector and watching the CEL flash out the codes? Does the CEL even work? With key on and engine not running CEL should be on. Is it on?
I have heard of cases of people removing the CEL bulb when selling a car so the prospective owner thinks there is nothing wrong with the car.
10-27-2021, 06:15 PM
(This post was last modified: 10-27-2021, 09:27 PM by Turboscott.)
The only time the CEL comes on is really dim when key is off. That a sign the PCM bad? Man that sucks.anyone have one laying around for sale on here? Thanks for reply Jeff
