natmac3
Mar 2002
Aberdeen, MD
Does anyone know offhand, the proper Lugnut for an aftermarket mag-type wheel on an 88TC.
I know the stockers won't work, and I'm sure I need the closed-end ones, but I'm not sure of the length or thread pitch.
If it helps, the wheels are American Racing Rebel chrome, 17x9... And again, going on an 88 Turbocoupe.
Anyone got some numbers?
THX
--n8
What every bird needs
1987tc
ThunderChickenTC
May 2003
Cincinnati, OH
no numbers, but i really do like the cup holder stunt. Nicely done..
88 TC ....Custom window tint, American Racing 15" rims with Michelin X-radial tires 215-70-r15, 9mm Ford Racing Spark-plug wires, K&N air filter, 3 core radiator, 180* Thermostat, Head completely rebuilt with an upgrade to a roller-cam, Silvannia Silverstar Bulbs for headlights, Painted wiper blades, XM Radio, Custom system with a custom built 5 cu. ft. box(2 and 1/2 cu. ft. per sub.), Custom Alarm System. Next is Magnaflow exhaust mod!!!
BCA
May 2001
Dowagiac, MI
BCA
If you can fit a regular sized 13/16" socket in the wheel than you can go with either a Gorilla lug nut # 71188 or a McGard lug nut #64000 (pack of 4).
Wheel stud size is 1/2"-20
You can use your stock lug nuts to get you by but you are going to be one short on each wheel since these wheels are 5-lug.
1985 Cougar XR-7 5-speed - 1 of 7,860 built
1986 asc/McLaren EuroCoupe - 1 of 47 built
1971 Ranchero
NATO member
1971 Ranchero GT
natmac3
Mar 2002
Aberdeen, MD
Thanks for the numbers, and thanks for the props on the sig link...
And it wouldn't be a problem at all to use the stockers, seeing as I managed to snag a 4-lug set. *insert evil laugh here*
I'll have pix in about two weeks, when the tires come in, and the wheels go on.
Figure it's about time to have SOMETHING of mine in the showroom...
THX again-- n8
1987tc
karnage
Mar 2003
Olympia, WA.
I just used my stock lug nuts and some gorilla locks for my TC.I have 17 inch centerlines and had no problems.I believe they are 1/2X24 or something like that.very common lug nut.
