Hey guys! It's been a while since i've posted and i've been having this dilemma over the course of a few months.
I have an 87 TC with the cone K&M Filter mod and the Gillis Valve, otherwise stock. My TC had a turbo go out shortly after i got it. Previous owner had ran some stop leak thru the coolant and figure it was due to coolant leaking into exhaust or possibly HG issues. Either way, when the turbo went out, i was getting a ton of white smoke out the tailpipes. I bought a used IHI here on the boards, and finally got the new turbo bolted up last weekend.
Heres what i did: Flushed the coolant system to try to remove the stop leak, and so far no leaks. As suggested i pulled the coil wire and turned it over for about half a minute in sessions prior to starting after i got the turbo on, to feed coolant and oil into the turbo. After that, the car fired right up. Also, no smoke was coming out of the exhaust at idle, a huge improvement from the old turbo as it had always smoked a little, especially after it started failing.
I let the car idle for about 30 min as suggested by a mechanic friend, then i revved the engine to about 3300 rpm to engage the turbo and see if it spooled up. At first, the white smoke returns when the turbo was engaged. I turned off the car and tightened up my clamps / bolts / etc just to be sure, and readjusted my gillis valve to max boost around 8psi. Restarted and no longer get white smoke out of the exhaust. I now get white smoke spraying out the top of the IC when i rev up to 3500 rpm. I thought this would go away, but over several days of me checking the car and letting it run, it will hit 3500 rpm, bog down and running rough with RPM quickly dropping, and white smoke spraying out of the IC.
I have 3 kids and we're a single income family so i'm pretty much left to do this myself... A trip to the shop will net way more than i can afford and not many around here seem to know anything about the 2.3 / IHI. I'm hoping someone here has some insight, and i appreciate your time for reading.
Boost on!
Boost on!
1987 Thunderbird Turbo Coupe
