23027
Aug 2007
South Surrey, British Columbia, Canada
So it's time to get rid of the PRC's.. *tear*
Wondering what are some good adustable shocks I could use? Price is somewhat a factor..
turboedthunderchicken
Nov 2008
waverly,oh
strange has some nice 10way adjustable shocks and struts for the fox bodys
1988 turbocoupe(boost controler,15psi,2 1/2in custom exhaust,4.10 gears not sure on rest
1978 ford fairmont futura 4.6cobra motor
1980 ford fairmont sedan 302 with juice 10.8 at 130mph
Shannon Clark
Nov 2004
Dubuque, Iowa USA
Thats what I replaced my stock shocks with. The fronts are a direct replacement...You need to reuse the tops of your old prc's.
The rear shocks will work with a set of Chucks adapters.
http://s14.photobucket.com/albums/a325/s...k23002.jpg
http://s14.photobucket.com/albums/a325/s...cks006.jpg
http://s14.photobucket.com/albums/a325/s...cks003.jpg
11's in a TC.........Soon
Currently 12.002 @114.77
11's next year I promise!
23027
Aug 2007
Okay well before I do this, my car sits lopsided driver side is a bit lower than passenger side..
I thought the springs may have been just softer on the drivers side so replaced those and it was the same business, so now I think the struts just have some gas leaked out of them from always having more weight on the drivers side.
Anyone agree? I'd hate to get rid of such a nice feature if it's not the case.
And on that note; You can't re-fill the struts can you..? I know they are sealed but are there companies that can re-gas shocks and re-seal?
23027
Aug 2007
Just looked up the struts at this site
I noticed the fronts say "V8 Applications Only", does this not apply to our T-Birds?
So I re-use the tops of the fronts, and get Chucks adapters for the rears? Where can I get these adapters
If anyone knows them at a cheaper price elsewhere don't be shy to speak up
Thanks
Jeff
vegas_ss
Jun 2005
Las Vegas, NV
I certainly wouldn't reuse the strut mounts... get a set at Napa for a v6 or v8 t-bird. Search on strut mount for more info...
TCx2
Sierra Vista, Arizona
My bird sits low on driver's side as well. New PRC's and about 42k on the car as a whole.
Kevin
TCx2
turbot79
Sep 2007
houstonTX
how are the strange struts and shocks as far as handling curves i see they have the coil over kits for the fronts and look a little less expensive than billstiens or konis
88 tc, hbc, t3t4, 3"throttle body,3" stinger exhaust, msd, 18psi, Tial 50mm bov, Esslinger adjustable round tooth timing kit, rods header on the way and many more to come
Robert Camp
Jan 2006
Raleigh, NC
Shannon, you say direct fit. I take it that the spacing between the front strut mounting ears is right for the 87-88 TC spindle? No need for spacers on the spindle mounts?
A better way to put my question is: Are the 87-88 spindle strut ears the same thickness as the 87-93 Mustang???
Robert Camp
motormenace
Jun 2001
Timonium, MD
Yes, they are the same thing (I have them on my 86 TC). I recommend Maximum Motorsports Caster Camber plates with any of the 94-04 mustang struts for the front. If you lower your car, you can use the 79-93 struts due to travel length, but still recommend the 94-04 ones.
86 turbo coupe (14.12 at 15 psi. sleeper) *gone*
...so you have a V8...isn't that cute...
